Re: Evinrude XP 10 Water Pump still problems
The thermostat is located rear of engine above the top sparkplug, should be a plate/cover with 4 screws, under the plate/cover is the thermostat and spring. The thermostst body is the bypass valve and the spring controls pressure. Depending on year of engine. Remove the thermostat and run engine, you should have a gusher of water come out of the hole where the thermostat was. The waterpump also has to have a seal above the inpeller cup, may be on top of pump housing, seal looks like an oil seal, if this seal bad or missing will not pump enough water. After you have done this and you still over heat the water tube grommet under the power head is causing a restriction, you will have to remove the power head to replace the grommet. The grommet is a common problem with this engine. The fix is when you install the grommet, the grommet should fit under the flare on the copper tube, this will make the tube about a 1/4 inch shorter. You can gain about 3/16 of the tube back by unbended the bends and rebending, then insure the watertube goes into the waterpump housing grommet to seal.
