Bassmaster48
- Feb 23, 2020
- 4
New guy here, went to the ramp last month motor wouldn't turn over [85 evinrude 140hp], checked the obvious with no results and ended up jumping the starter solenoid for the day. Not sure if related but the radio every 5 minutes would get softer and softer until no audio. So as of today I'm about to pull my hair out, I installed a new solenoid without testing the existing one.. dumb and still nothing when turning the key. checked continuity of kill switch and neutral safety which checked out. I have 12v at the key switch terminal B but then have 1v after turning the key. Bought a new key switch, same result. With the key off 12v at B with key on 1v at B and 1v at A. I have power to everything else on the boat and 12v at the battery when turning key to start. Faulty switch, short, something stupid? Any thoughts or ideas are appreciated. Thank you
