Hi! Have a 1990 200hp Evinrude that have been leaking fluid through the top seal for quite some time. It have been getting worst so I decided to replace the seal on the shaft. I already ordered the kit and was able remove only the tilt cylinder without the rest of the unit. I was also able to remove the top cap with a grinder tool that fitted perfectly. My big question is, how do I get the center seal from the cap out? The lower part of the piston that goes inside the cylinder housing has some kind of nut that I was able to remove and it secure a washer that compresses several small springs but that piece of the piston does not move so I'm nor sure is this will come off or if I have to remove the other side of the piston (where the big pin attaches the swivel bracket) that looks more difficult to remove. Will appreciate more help on this procedure as it is the only step holding me of fixing this cylinder.
