Evinrude throttle conector install
MrT5555
Hello- I have an Evinrude 1993 4hp that the throttle cable connector cracked in half. so the throttle cable end does not stay in. SO in the process of messing around with it I also broke the cable. I have a new connector and cable coming. Do I have to pull the top of the motor off to replace the connector ? its a pain to work underneath the flywheel. Also does anyone have a schematic on how the cable connects to the thing. I tried several ways and beings its cracked the cable never did stay in it. I am trying to figure out a way to replace the connector and cable as easy as possible. Nothing worse then having your 17 yo grandson sitting in the front yard with a disappointing look on his face when the old outboard wouldn't rev up. Also- does anyone have any info on the choke location. the know was stripped out and I cannout figure out how to know if the choke is on or off.
Thanks again the motor model# is E4RETB
MrT5555
Somebody has to have an easy way to get the black plastic piece out of underneath the flywheel. can I just pull it down with some needle nose pliers or do I have to pull the flywheel off.
