96' E130TLDEM
The starter does not engage the flywheel on every occasion. I am assuming that the drive assembly is damaged as I see no wear on the gear protruding from the starter.
Is it probable that the drive gear is the damaged component and if so do I need to order the complete assembly with the spring and bushings included or just a new drive assembly?
This seems to be a pretty straight forward repair, correct?
