Evinrude runs whan bulb is primed
I have a 1988 200 Evinrude (oil injected)and just got a new water pump installed, when I took it out for the first time after that, I was out about 20 min and the engine was running ok then it quit. I restarted it but it kept stalling out. However when I kept priming the bulb it would keep running.I changed the primer bulb and the hose that led to the engine from it but it still does the same thing. Am I sucking air from somewhere??? or the fuel pump maybe??Anyone have any ideas what to look for.. It almost seems as tho it's running from the gas that's primed to it , then it quits when it runs out....and the primer bulb seems fairly empty...
