Evinrude Prop
bsoehnge
I am replacing the prop on my 1961 Evinrude Lightwin. The prop has a brass bushing in it that seems to be held in place with some sort of "packing" material. My question is, "How do I move the packing material and brass bushing from my old broken prop to my new prop?" Thanks!
rwise
Re: Evinrude Prop
unclebob<br />take it to your local prop shop! if it can be used in your new prop they can do it.
Dhadley
Re: Evinrude Prop
How did you get a new prop without a hub in it?<br /><br />Its pressed in under tremendous pressure. Im sure it wouldnt be a good idea to reuse one.<br /><br />Good luck!!!
Spidybot
Re: Evinrude Prop
BUT..? In 1961 Evins used a break pin on a straight shaft without splines - not a rubber hub insert. Those days only Merc used it as they had the patent..<br /><br />So, a prop for that is meant to have no rubber. And the bronze-alike tube is part of the prop and not interchangeable (unless you're a prop-wrokshop).
