Hello,<br /> I have a problem with my '96 e-rude 150 60 deg looper. Engine starts fine and runs fine at all rpm's until I shut her off and let sit for a while. When I try to restart, the engine will idle but try to throttle up and engine boggs, like starving for fuel. Checked compression, fuel line is fine to the pump, including bulb, filters are clean also, and carbs clear. When I have the engine running at idle, and move the primer lever to 45 deg for a second, seems to help, but put it back to run position and boggs again. Eventually the engine will run fine after many attempts at throttle. Any suggestions?<br />Thanks
