Evinrude Oil Injection Problems
Waden
Anyone that has had problems with the oil injection problems with Evinrude<br />motors in the last 4 years please contact me.<br />Wade Noland<br />227 Scenic Drive<br />Eufaula, AL 36027<br />334-616-7981
neptune202
Re: Evinrude Oil Injection Problems
I let the oil resevoir get low and the VRO alarm whistle came on, refilled it, yet the alarm still goes off every 40 seconds. It's getting oil because it smokes badly at idle and the resevoir level drops correspondingly with fuel consumption. How do I get the whistle to stop?
Peter O
Hi Waden<br />Can I suggest you post your email address for replies? I am sure you will get alot more responses. Sounds like the beginning of a class action??
clanton
I dont think OMC has any money.<br /><br />Neptune202 unplug sensor wire to remote oil tank, if alarm stops, clean tank or replace.
fredmfl
Try pumping the oil line bulb til the sound stops. Sounds like you have air in the injector.
dick
OMC is dead , Chopped up into little pieces. Bombardier has owned the Outboard side(JOHNSON/EVINRUDE)for almost two years now .
rickdb1boat
Check float in VRO resevoir! May be sticking.
