Re: Evinrude Ocean Pro 200
Thanks Kenny,<br />Thanks Kenny,<br />I didn't get the WOT, but should have. The engine looks well cared for, but no specific maintenance record. I'm going to take it to my mechanic for a look see. It does have a new electronic package on it. I also noticed that there's a timing adjustment on the front of the carb cover which is something I hadn't seen before. I'm assuming it needs to be set by a pro and not messed with, correct? It's got two props, a 3 blade 19 degree and a 4 blade 15. The test was on the 19, which seemed to push it fine. The 15 is supposed to have some serious low end power. I'd be interested in how yours is propped as I'm not an expert on that either. <br /><br />FYI, There's another post from last night from qapd concerning a water pressure gauge for this style engine that I replied to. Do you have a pressure gauge and if so where is the sensor tapped in? <br /><br />THanks again for your help.
