Re: Evinrude Misfire
Looked at my boat today. Have a couple more questions and might have found some problems.
1. The wires from the rectifier are shot. So I know that is a problem and I have the replacement part on order.
2. During my snooping around I found this crack.
The crack is on the top of the can and the second picture with the letter "A" on it is the side of the same can. According to
Evinrude Intake Manifold Diagram, I believe this to be part #17 "SOLENOID ASSY.,Choke". Should I be concerned with this crack?
3. Using the pictures from above. Part labeled B, according to the
Evinrude Intake Manifold Diagram, it is part #30 "LINK ASSY." Right now it is just dangling down. Where exactly is this supposed to go?
4. I know this is an engine group but today, after I found the stuff above, I turned my focus to my live well pump. It wont pump water into the tanks. I took the pump off and connected it directly to the battery. The pump worked. I hooked it back up to the original electric rig and turned it on and it worked. I flushed the intake tube to clear them of any debris. The tubes are clear. I connected the pump back to the tubes and dipped it in some water. It blew the fuse. Next I took the pump back apart and attempted to hook it up directly to the battery. The pump wont turn now. Is my pump now broke to the point of replacing? If I get a replacement pump, will that pump be damaged because the wiring is wrong?
