I changed the gear lube in the lower unit and it was very nasty. Don't know the last time it was changed before I purchased it. The top vent/fill line plug has a black rubber gasket on the plug and there is a plastic gasket that is around the threads of the fill line hole.
On the bottom drain plug, the plug has the black rubber gasket, but I did not notice a plastic gasket like the top plug has. Is the bottom plug also suppose to have a plasic gasket in addition to the plug gasket? Thanks for any info.
