Re: Evinrude keeps blowing fuses
island_boater,<br /><br />Schematic gives good advice. If you're not sure about your abilities with test equipment, I suggest these.<br /><br />Do the simple things first.<br /><br />1. Check every coonection under that hood-take them apart, clean and reconnect. Make sure the battery is DISCONNECTED.<br /><br />2. Start looking at the wiring going from the engine to the control box. Inspect every inch of it.<br /><br />3. Make sure the starter attachment bolts are tight and clean. Ditto for the solonoid. Make sure the elec. connections to those copmponents are CLEAN.<br /><br />4. Follow Schematics advice, Im not sure which guages you have. Determine which ones become "live" when you turn the key on. Typically these will be the trim, tach, fuel and volt meter. Disconnect them and try. Reconnect one at a time until the symptom repeats itself.<br /><br />I still believe you have a poor connection somewhere. Especially after you mentioned that someone has been in there before.<br /><br />If you are CONVINCED that you have checked every connection, check them again. So far you won't have spent any money. The next logical component is the starter solonoid. These are not dreadfully expensive.
