i have a 25hp evinrude ca 76mob with some johnson parts
problem is to get it started.
Good comp ca 100psi in both silinders
sparks in both sparkplugs (new also)
i can make the exhaust go bang with a lighter
so im guessing its the timing?!?
i have changesed fule filter and lines
cleaned the carbs adjusted the nedel to 1,5 turns (and truyed litle up and down)
and some times i only get one bang every 2-6 puls or more depending on my adjustments
how can i duble cheak eks top piston on dead sett senter and ignision marks.
it seems to be almost to the far left in the end then ... is that right?
and advice?
and advice?
