deeman7777
- Sep 29, 2005
- 51
When I prime the fuel line, gas sprays out of the fuel pump where the cork gasket is.
This motor is brand new to me - 1968 9.5 evinrude.
The motor also needs to have the fuel bulb pumped or it will die out.
I disassembled the fuel pump and did the blow test and could not blow into either port - I know you're supposed to be able to pass air through the intake port. I may have reassembled it wrong - or maybe it's always been like that....I did not test the pump with the blow test prior to taking it apart.
I found some great info on the fuel pump here and the assembly directions - but thought I would throw this out there to see if all 3 of these symptoms can help someone make an assessment.
Many thanks!!!
Mike
Many thanks!!!
Mike
