Re: Evinrude Fisherman 6HP won't run on shift or slow setting
If it seems like it is idling smooth and at the correct idle RPM when the throttle is at "Start", then it may simply be out of adjustment. If it will just not idle low, then the low speed circuit in the carb may be clogged and the carb will have to be removed and cleaned.
