Evinrude fisherman 6 HP Carb ?
blllyjack
Hi<br /><br />Motor runs fine but seems slow. Had the carb apart and around the bottom of the main jet was a rubber washer. Looks like it makes a seal between the main jet and the bottom of the bowl. It was disintegrating so I replaced it. Looks like fuel has to come around by the drain plug and up to the main jet. Seems odd. Should it be there ? It might restrict flow at high RPMs ?......<br /><br />Back again.. Just had it apart. Seems there is another jet in the bowl next to the drain plug. I cleaned it with throttle cable wire. Seems to be open more. Will try it out this afternoon.
