Evinrude Ficht tilt and trim wiring diagram
MrSnailBoswel
I couldn't find anything online so I created my own from a 2006 90hp. Though I'd share it here. It may not be 100% accurate. Please feel free to comment if something is wrong. In my case, the culprit was a loose pin in the PD2 connector resulting in no power at the motor.
Crosbyman
90hp 2006 should be an ETEC no ? POST YOUR ENGINE MDL #
In any event when you need info you can also ask CHATGPT which can provide diagrams for you . It will search theentire web for you
MrSnailBoswel
Hi Crosbyman,
It says Ficht Ram 2006 EPA on the cowling. I Could look up the model# but I assume the diagram is the same.
Thank you,
Crosbyman
CHAT GPT will provide a diagram for 1987 and up if you ask for a
" 90hp Ficht Ram 2006"
