Evinrude ficht lower unit stuck!
Hi I have a 1999 ficht 225 and cannot seem to drop the lower unit.Im dropping it to replace the water impeller and have done it before on older outboards but this one is giving me a problem. I took all usual bolts off to drop it but it only came down a few inches.It seems the rod nearest the boat is holding it on(I believe). Like I said all bolts are removed. I have tried all combinations of reverse, drive, neutral,ect but no release of the unit. So how do you disconnect this thing thanks!
:confused:
seahorse5
Re: Evinrude ficht lower unit stuck!
Have you removed the shift rod to clevis bolt that is situated underneath the throttle bodies?
Be sure to measure the shift rod length on the gearcase before re-installing the lower unit or you may damage the clutch dog lugs and a gear or two.
Refer to the service manual for the measurements and proper shift adjustments.
