I have an evinrude ficht 99. The warning buzzer goes off continuously as soon as you turn the key on. Ive ordered a new buzzer but I do not believe thats the problem. I don't know where to start after that, any help would be great!
The manual will tell you what sensor may be activated, if not, you need to disconnect each sensor one at a time to see which one is causing it to sound off. The gauges from that time frame tended to fail often.
I do not have the manual, its on the way. i disconnected the pack with the six tan wires and it shut off. I tested each wire side the pack the black wire made the alarm go off. Im assuming it goes to ECU. But I'm not sure and I'm trying to avoid tearing that wiring harness open to follow it
If a dealer could not tell you why the alarm was sounding it is time to find a different dealer!!!!
Being one of the large troublesome ficht motors, first step is a compression test to make sure you should even bother looking into this.
If no codes were found the next thing to do after a compression test is to plug a known good sytem check gauge into the harness under the dash. These frequently go bad.
I also would not be running this motor more than I had to while diagnosing.
well its been running for three years three times a week minimum with this alarm. the motor has been checked multiple times since then. I was wondering about the system check. would it sound the alarm and not show lights?
I hade several system check units fail, some the alarm just came on for no reason as soon as you turned the key, others wouldn't come on at all, and one the tach wouldn't work.
Get a different gauge. I just disconnected everything one at a time, when the last one was disconnected and the alarm was still on I knew it was the gauge.
If the dealer actually is a dealer/ with a computer diagnostic program, and the brains to use it (which is doubtful cause they should have been able to figure this out years ago for you), and you have been running it with the alarm going off for three years, and it still runs, and you installed a new buzzer, then that all points to the system check gauge.
Sometimes DIY is not less expensive...as a tech one of the "tools" we have is a known good sys check guage.
If I were in your shoes I would find a dealer with lead techs old enough to have been around for the bankruptcy and take it to them. Tell them what it's doing and get it fixed right. You have the motor that put them out of business.
Apparently yours was put together on a Wednesday cause it still runs.
The rest is up to you. I know of no other easier way than what was said above in several posts...
With no offense intended and all sincerity due, I wish you good luck and happy boating.
