I have a 1992 Evinrude 70 HP. I'm having trouble with a wire that runs from the where the negative terminal on the side of the motor, under where the positive is. This wire runs from the negative terminal, under the engine and to 2 grounding point in the trim/tilt area. The wire keeps burnning up. When I got the motor, it was an exposed wire. After the first problem with it, I replaced the wire with a coated wire. It worked fine for about 3 trips out and now the wires melted. Does anyone have any idea why this wire would melt?
The wire melts when I go to start the boat. The starter doesn't get enough power to spin the starter properly. I disconnected the wire and the starter gets no power and the trim/tilt is dead. When I replaced the wire (with the coated wire), everything worked fine for about 3 trips.
