Evinrude E25TECSSA water pump
murrayw91
I took the Lower unit off to replace the impeller, but it was not bad. When i start the motor back up i get water for a few minutes then it stops...<br /><br />Any ideas?
OBJ
Re: Evinrude E25TECSSA water pump
Murray...when you say "not bad", does that mean the impeller "fins" pop out straight or did they stay bent as in the shape of the impeller cup?<br /><br />Does the engine overheat? If you are looking at the tell tale peeing water then stops, did you try to run a wire up into the hole to see if it was clogging up? Sometimes you need to take the nipple out and let the hose run full to clear it.
