evinrude carbs
sambrigman
i have a 90;s 40hp evinrude carbs have a black plastic top. When i pump the bulb, gas shoots directly out of the vent in the black plastic, the lower one does not.whats up? thanks guys
Crosbyman
carb and toilet bowls work the same way... the raising float stops the inflow of water...or fuel in a carb
when either one does not work you have overflow :)
take the carb apart , inspect & fix the mechanical issue stopping the inlet needle from doing it's job of shutting the inflow of fuel .
on older carbs with cork floats...some get " fuel logged" & sink and never float up to stop incoming fuel
check for warping on the plastic top
sambrigman
that is what i thought also. The float is working properly, there is a port hole connecting the fuel to the top before it gets to the float
There is an issue with the float or float valve.----That is why one carburetor is leaking !----What port connects to the top ?-----Pictures needed so we understand what you are talking about.
sambrigman
the black plastic top has notches 2 on each side. squeez the bulb gas shoots a foot out of the notch directly above the gas inlet nipple
There is an issue with the float / float valve.----Take carburetor apart and inspect.
sambrigman
i have taken apart and cleaned. Float and valve are working perfectly. The gas goes directly to the top before the float chamber. I am going to try and seal the vent
No ----I do not think gas supply for the carburetor goes to the plastic cover.-----The wee hose from the primer valve ( it is not a pump ) injects fuel when key is pushed in during cranking.----This fuel does not go to the float bowl or metering circuits in the carburetor.
