Evinrude Carbs Leaking
racerfern
Greetings, I recently purchased a boat with an Evinrude 140 2 stroke. E140TLCEB. My issue is that when I tilt the engine up out of the water, quite a bit of fuel leaks out of what I believe is the float bowl vent hole. When it happens, fuel drips onto the lower cover and apparently also into the intake which floods the engine. It appears to be all four, but it might just be 3 of the 4. Is this a float level adjustment or something else?
I'm ok with ordering whatever parts I'll need since it appears to be quite easy to work on. Thanks in advance. This is my first boat and my first posting on this forum.
boobie
Take your carbs off and check your float levels. Also make sure the gaskets and hoses on the air box are all intact and connected.
racerfern
OK, I I replaced the floats along with he needle valves and seats. I was surprised there was no float level adjustment possible. There isn't even a specification as far as I can tell. I also changed the plugs and fuel filter. Surprisingly, there was no dirt or sediment in the float bowls and it also had no evidence of varnish buildup.
I fired it up, got to operating temperature and shut it down. Upon raising the motor I still got a couple of drops of gas dripping out but nothing like before. Tomorrow will tell, I but I think it's about as good as it's going to get.
racerfern
Well, apparently I didn't dig deep enough. I had the same flooding issue though not nearly as bad. Come to find out a bit more research showed how to adjust the float tab to get the proper fuel level. Tomorrow will tell.
