reconotdor
Thread starter- Joined
- Jun 26, 2003
- 21
I have a 1963 evinrude 10hp outboard. I had trouble with it this year after it had set up for about three years(it would start, but bogged down and stalled unless the choke was constantly manipulated). I cleaned the carb and it starts and runs good at an idle, but when I open it up it will only rev high for a couple of second, then bog down(it keeps running, but at a low idle even though it is opened up). It will run at this low idle (about trolling speed)all day, but never runs at a WOT. I have replaced the fuel lines from the tank to the carb and all fitting are tight. If I pump the bulb while the motor is running (bogging) there is NOT a change in the engines performance. I have looked at the fuel pump and the diaphram looks like ****(all cracky and stiff). I have been told by parts dealers that I can't buy a rebuild kit for the fuel pump and a new one is ~$50. I wanted to make sure this was my problem before I invested more money into this engine. Does this sound like a fuel pump problem and/or what else could it be?
