Evinrude Big Twin 30 parts
jperry1444
i need advice on how to find parts for my '56 Evinrude Big Twin 30 hp. i located the part i need in the parts manual (376467) the part itself is stamped with 304207. It is described in the manual as "H.T. lead to armature plate anchor. it mounts to the underside of the magneto.
How do i find these sorts of parts?
Thank you.
Jim
Joe Reeves
Re: Evinrude Big Twin 30 parts
A "H.T. Lead" would be a spark plug wire. If this is what you're looking for, you can find it in most any auto parts type store. Just make sure that the inner core is actually wire, not carbon.
(Replacing Regular Spark Plug Wires)
(J. Reeves)
If you also need the spark plug boots and the spring terminals that connect to the spark plugs, purchase them from your local dealership (OMC Part #581027). This includes one boot and one spring connector. Price is about $3.25ea.
Purchase whatever amount of spark plug wire you need. Be sure to purchase the kind that has a steel twisted wire leading through the center of it....... not the carbon type plug wire that many automobiles now use.
Using your old plug wire, cut the new wire to a length about 3/4" to 1" longer. If you have no old plug wire, just make sure that the wire is longer than you'll need as you can trim the other end later.
The rubber boot, spark plug end.... With the wire cut to the length required, trim back 1/4" insulation again but do not solder tint the wires. Simply fan out the wires and fold them back against the insulation, cutting the excess off as explained above. Holding the spring wire terminal, estimate where the prong should be inserted so that the spring will be flush against the exposed wire. Hold the spring terminal away from the wires end (sideways) and insert the prong into the insulation and into the center wire, then swing the spring terminal in front of the exposed wire portion (makes a tight fit for continuity purposes).
Spraying the inner portion of the boot where the wire will insert with a small amount of WD40 makes the installation of the wire a easy project. That's it.... you're done.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay auction at:
http://shop.ebay.com/Joe_OMC32/m.html?_dmd=1&_ipg=50&_sop=12&_rdc=1
