Re: Evinrude 9.9/15 carb - still won't plane
Boy! You wouldn't believe the difference! I took both yours as well as Corm's advice, with the following results:<br />1. The tachometer setting on the back of the instrument was set improperly. The boat originally was delivered with a 40 hp Johnson, so the tach was set by OMC for it, thus, it was reading far lower than it should've. Trouble was, the original dealer said there were no adjustments on the tach, and further, "9.9 or 15 h.p. motors don't have adequate alternators to run a tach reliably, so they might indicate lower than normal, so you just have to live with it!" What rubbish. Last visit I'll make to that dealer. I set the tach to 5 as advised me by another OMC dealer and voilla, the tach reading came up to 5000 with a 10" pitch prop. Still 10 mph though and bow hig, hmmmm.<br />2. I replaced the prop with an 8" pitch.<br />3. I installed a doel-fin on the cavitation plate.<br />4. Yesterday, with a radar gun, (I don't trust low speed readings on pitot tube speedos,) I was clocked at 18 mph and the boat was planing beautifully! In fact, the bow attitude never rose like it did before the whale tail was installed. The gadget really works! RPM is now up to almost 6000 at max.<br />5. Don't know about the leaf plate assembly yet. I guess I'll have to order it and see if it continues to make a difference. Where does it go, under the carb?<br /><br /><br />
Originally posted by Capt DHD:<br />Hello;<br />The intake plate is different on the 2 engines as well as the carbs. Your poor performance may be associated if all you changed was the carb.<br />A good running 15hp should plane the boat your describing pretty easily I would think.<br />The leaf plate assy pt# you need is #390050.<br />Hope this helps<br />Rob
