Re: Evinrude 9.5hp to 15hp quality conversion
Try pulling the starter cord slowly a few times, with the kill button pressed. Does the resistance going over feel the same on both cylinders, or can you repeatably tell one cylinder from the other? If they're the same, you're cylinders are likely OK - it's rare for them to be able to wear down at the same rate. If one turns through top dead center with little resistance, then that's at least part of your problem. <br /><br />However, even a leaky cylinder produces pretty decent power, so sounds like it may have other problems. Does it seem to run smoothly? Did this problem just occur, or has it slowly built over time. <br /><br />The 9.5 is a great motor, but is basically a hopped-up 7.5. The 9.9 looks the same, but is basically the 15 with a smaller carb (and in some years other tuning changes). Thus the 9.9/15s are a good deal stronger than the 9.5, but also heavier. A good running & well-propped 9.5 ought to be plenty of motor for a 12-footer.
