I bought this '69 9.5 9922s off craigslist for cheap, it was a divorce sale and I didn't get much info on it.
I'm not too familiar with outboards but I have worked on lots of lawnmowers and other small engines. This appears to be missing it's fuel pump, prop and cone. Do you see anything else I'm missing? Everything appears to be in good working condition, the grease is still soft on all the moving parts, rubber for exhaust is still soft and supple. Pulled the plugs and compression is 73 on both cylinders. A few drops of fuel in the carb and it fires off on the first pull.
So, a fuel pump, prop, cone and pin, new lower seals and oil, clean the carb, cross my fingers and pray it all works and I'm not wasting my money..
Sorry for a lengthy first post! Here's a few pictures, please tell me if you see anything I should be aware of. And if you have an extra prop let me know, this is a budget build and the cheaper the better. Thanks!
