evinrude 88 spl wont start
coosarunner
was warm today so i got out the boats. 72 bomber with the 650 mercury ran like a champ on questionable gas. 80 glasstream with an 88 rude wouldnt start. only 1 out of 8 times did the starter engage the flywheel. it just spun, fresh battery and all?any advice?
OBJ
Re: evinrude 88 spl wont start
How ya' doin' coos? Try this. Take a little WD-40 and give the shaft right above the starter gear a little squirt. Work the gear around a little to get the lube down in. Just a little squirt will do. Then try it again. If it jumps to the flywheel, your in buisness. Lube the starter shaft with some bendix lube and you should be good to go. :D :D
coosarunner
thanks ill try it it tommorrow if it doesnt rain
coosarunner
thanks<br />that did the trick, fires right up.<br />but now its gotten cold and rainy. shoulda known i might as well wait
