lobsterboy
- Jan 9, 2002
- 7
Need some help! My 1992 Evinrude 88 SPL is over temping on 2 cylinders. I still have good water flow out of the pee hole. Noticed alot of corrosion around the head gasket on the hot side. The manual I have does not show the cooling water flow paths. This over temp happened while I was running it at idle in the driveway. Is it possible to have one head path clogged and still have a visible flow? I have about 50 hours on the water pump. Are there any manuals that show the cooling water flow path?
