Re: Evinrude 85HP /1980 - Trim gauge calibration
Hi, I have a 1980 evinrude 85hp V4 model# E85TLCSA and want calibrate the trim gauge indicator.
The system works well, except that the needle is out of range: It gets to the "inside full" from the beginning of trim. Any help?
Thanks.
Assuming that your trim sensor sending unit which is located on the inside portion of the port transom bracket is in good working order, do the following.
Position the tilt reverse locking bar in the center hole of the transom brackets.
Lower the engine to that reverse tilt lock bar.... observe the reading of the trim gauge.
Loosen the retaining screws of the trim sensor sending unit slightly so that you can adjust it up or down as needed to center the gauge needle. (The retaining holes are slots)
The sending unit can be tested with a ohm meter. The wires of the sender, disconnected from their usual source, when connected to an analog ohm meter, should cause the ohm meter needle to move smoothly from one extreme to the other. Any loss of movement or jerkiness... replace the sensor sending unit.
When finished, remove the locking rod from that center transom bracket hole and return it to wherever it was.
