I am in the company of a 1992 Evinrude 8 hp that has over heated. The impeller failed and she cooked. In fact, the throttle linkage arm, the water outlet indicator elbow and the thermostat housing all melted.
I have her back together and she will run well but she doesn't want to start. I am blistering my fingers. I have gone through her, carb to ignition.
The carb is totally clean. If the carburetor is the cause, I am totally stumped. She started and ran very well before the overheat. I don't know what I would ask about the carburetor. I've been completely through it.
I measure the compression at 80 psi in both cylinders. I am not used to seeing this low a number. The other Evinrudes I have worked on are in the 95 to 110 range. Is 80 too low for cold ignition? Maybe she really got hurt. Is this compression too low for a good crisp pop? She runs great when you can get her to start. What is the likelyhood the overheat creamed compression ratio?
I was hoping to keep her running without opening the case. I was really hoping the rings and crank would take it...
Thank you for any advice you can provide.
Jim
Jim
