Evinrude 70HP Bearing and Seal Replacement - Can not remove driveshaft
rosemb01
Hi,
I have an Evinrude 70HP 1980 E70TLCTE. I have removed the lower unit, the impeller and housing, removed the O ring and bearing at the top of the driveshaft. I have selected the reverse gear, (removed selector rod) and tried to remove the driveshaft from the lower unit with no luck. I have also removed the four screws in the Propeller housing and tried to slide out the propeller shaft, again with no luck. Is there a special way of removing the driveshaft and changing the bearings?
Help would be much appreciated
Many thanks
dew2
Re: Evinrude 70HP Bearing and Seal Replacement - Can not remove driveshaft
Once the bearing house assembly comes out there are two retaining rings to remove.Do you have a manual? schematic? You will see it with either.I just went to BPR I think their site is down.Try This one.I see that motor is a 1983 also.
http://www.crowleymarine.com/johnson-evinrude/parts/44408.cfm
rosemb01
I do have a schematic diagram, in the diagram I have removed bearing and O ring 41 and 36. O ring 48 is still attached.
Is this the retaining ring? If so, how do you remove this without damaging the housing. I am trying to replace bearing 2.
The driveshaft comes up about a cm, then it hits something, (gear?), I have selected fwd, rev and nutral gears but still only comes out a cm. I have attached photos.
Mrkoolbreeze
your going to need to rig a puller to pull the prop shaft bearing carrier then pull the four screws that retain it ,once that is out you will need some special snap ring removers , remove reverse gear remove pinion gear then pull drive shaft. you really need a shop manual for it though it is invaluable when working on these engines. :) William
