Evinrude 70 hp VRO
Philby
had the boat in the water for the first time since fitting a new powerpack. At the same time I changed the battery cables ae they seemed a bit lightweight for the distance they were running.<br /><br />The enginge runs better than it ever has.<br /><br />Is this the powerpack or has the cable mad any difference ?
steve 2
Re: Evinrude 70 hp VRO
Powerpacks do go wrong,some pack in competely,some are intermittent,when this happens chances are that one cylinder is losing its spark,and losing power.say you run a 85 h.p v4 omc they do run on 3 cylinders,sounds like you made the right choice changing the powerpack but not sure about trying the boat out in this weather.catch you later,steve
Philby
I always said they were a bit soft in Yorkshire<br /><br />Thanks
