I have a 1978 model Evinrude 70. When I put the boat either in forward or reverse and apply the throttle, the engine boggs down and dies. I took the cowling off and with the boat in neutral, I moved the carburator linkage and the motor seemed to run just fine. I feel that it had excellent response and power. But when I put the boat in gear and gave it a little gas, the engine dies. would rebuilding the carbs help? What would make the engine die under a load? Any suggestions would be appreciated. Thanks
