Re: Evinrude 7.5
Hi SlugBug,<br /> I've had a number of 7.5s over the years and have never paid more than $75 for any one of them. With a modest amount of time and money I managed to return all of them to running order. <br /> FYI, your motor should have a built-on tank as it was the last year of the neutral-clutch Fleetwin model. That said, you won't need the separate tank. The neutral-clutch system works fine, but can be susceptible to previous fumble-fingered attempts at service. New waterpump impellers s are readily available (with a minor modification required to the impeller), as are ignition components. If the motor has solid compression (at least 80 psi in each hole) and doesn't make any odd noises when pulled over, then it's certainly worth somewhere in the ballpark you were looking to spend....<br /><br />- Scott
