evinrude 6hpfisherman 1973
suirpilot
cannot decide if I have ignition problem or fuel problem,engine starts perfectly runs on full power for afew minutes then looses powerand will run on low revs before stopping altogether. I have taken off carb and cleaned it but this does not cure the problem help
wilde1j
Re: evinrude 6hpfisherman 1973
Overheating? How hot is cylinder head when it stops?
sloopy
how hard is the primming bulb, you might have an air leek in the fuel line :) happened to me, I replaced the carb fuel pump and spent 200 trying to find the problem! then after all that I found out it was the lowzy fuel line!
