Re: Evinrude 6hp fisherman fuel pump
Remove the four bolts and drop the gearcase down far enough to access the shift rod connector. Remove a bolt from the connector. Now the gearcase will come thr rest of the way off....BUT there is a pin in the top end of the drive shaft that has to come down through a slot. Before starting, you should have removed the spark plugs so the flywheel is easy (and safe) to rotate. As you remove the gearcase, slowly rotate the flywheel till the pin aligns with the slot and will come through. After you get it off, note the position of the pin so you can later rotate the shaft to the same position for reinstallation. Do NOT rotate the flywheel while the gearcase is off and the crank splines will stay aligned for easy reinstallation.
If all fails and you shear off the pin, get a new one. Don't even think of leaving it out. It is vital to the health of the engine.
