Evinrude 60hp - won't crank no trim control
LeShrum
I just bought a 1988 Eagle 351 with an Evinrude 60hp outboard (don't know the year of the outboard). The trim control stopped working so I can't tilt the engine up or down, and the engine will not crank. The battery is fine, the lights and the bilge work fine. This happened while the motor was running. The guage that shows the trim of the engine, all of a sudden looked like I was raising the engine...when I tried to adjust up the engine up or down, it wouldn't move, and couldn't hear the small whine that I normally hear when adjusting trim. So I shut the engine off so that I could hear better, and when I was sure that the engine was not lifting up, tried to restart the engine...wouldn't even turn over. I've been looking suspiciously at a solenoid at the back of the engine...it resides between the battery and the starter on the engine...if this were bad, would it affect the trim motor also? Is there a fuse or something that I should check...I was also thinking of buying your Volume II (seems to be the one for my year boat) book on Evinrudes, would that manual cover this type of topic?<br /><br />Thank you, I'm really very new to this...<br /><br />LeShrum
clanton
Re: Evinrude 60hp - won't crank no trim control
Fuse on engine looks like real small red primer bulb. 20 amp short fuse. If your motor is great running motor, I would suggest you upgrade cooling system, I can give you numbers of SBs and waterpump pn .
clanton
LeShrum
Thank you, I think I saw what you described. Since it's still in the water at a friends dock, I'll have to go back to check it. I didn't want to start taking things apart with my limited knowledge (especially on the water). And the other info you offered...I'll look at anything that's sent my way, I'm that new to this. And yes...up to when it wouldn't restart, the engine ran very well...<br /><br />Again thank you...
LeShrum
Clanton,<br /><br />You're a gem...thank you. Total cost of repair... $0.53 for the fuse with tax. It was exactly where you said it was.
