Model No. BE7RSB..Belgium made, has the manual vertical starter, CD2 ignition, manual pull type primer, and plastic top carb with throttle cable...any ideas on year model?...slightly tuned 6 hp, or detuned 8 hp.?...the biggest problem is the powerhead to exhaust housing gasket < I think > is leaking profusely. If I can get it close to hp. and year, then ordering the gasket for the 6 and 8 both is a solution. I've found that the 1996 - 1998 model years yield something close as far as the BE goes, but no exact match to BE7RSB. Appreciate any ideas on where to find parts listing...AlTn...well, after speaking with owner,, ascertained that this motor came from the Bahamas in the 80's...found a close match on a 1988 8 hp..as it and the 6 hp. share the same exhaust gasket part no....gonna go that route if he wants it fixed
