csisommout
- Nov 17, 2008
- 231
hi, any expert out there. I have Evinrude 50 hp out board only know the serial # and model# up there. Can't go full throttle or above 1500 RPM, the motor tend to die, was running perfect last summer, a motor starts up and pump water very good. any ideas or advice will be appreciated, Cal s. Just checked L U and put in new gear oil. Thank you, again.
2, Does this motor have thurmostate?. forgot to mention this is oil injection motor by the way. is it may be something with oil and gas? what 2 cycle oil do I use for the motor? Thank you.
