Re: Evinrude 40 lower unit
I found it now - it is besides gas linkage, starter is on the other side. I will get a 55 HP 1985 motor same type from one of my friends this week. It has blown head (crankshaft, rod and housing) I will save it for parts, as gear is OK- do you know if gear ratio the same ? By the way, i got rid of the used black fat gearoil today - There WERE shavings in it - lots of small, but maybe this oil was in it from new. The gear seems to function OK - i feel no unnormal play in bearings -- shift seems OK.<br /><br />Will swapping carbs with the ones from the 55 increase power ?
