Hi All;
I have read several posts about idling problems with evinrude engines but I need some advice.
My evinrude 40hp is a 1989 model, the manual I have is basically crap with too much information that dont seem to match my engine.
The engine refuses to idle.
I have only had it for a short while and when I first got it it was a very slow idle, rough but it still idled.
Now it will not idle when in the water or in a tank.
Out of the tank it idles at about 500rpm and it idels without fail.
In the tank or water, it just stalls.
If Im quick enough I can get it into gear and be off and it goes all day at any throttle with no problem and plenty of power.
The manual states 750-850rpm at idle, but there is no idle screw to adjust it.
The timing seems ok and advances to the recomended 19 deg at 3500 rpm
If I operate the carby throttle without the advance, it accelerates, but rough (as expected).
I have fiddled with the slow speed mixture screws (taking care to know where it was originally) but nothing changed, so I put it back (about 2 1/2 turns from seated)
The carby control cam follower was about 1/4" away from the cam originally, I adjusted it to touch the cam as detailed in the book and it now accelerates much smoother, top end seems uneffected.
In order to keep it running I have moved the carby follower to touch the cam and hold a higher idle, this is not the way it is noted in the manual, but it seems to work and the motor still performs faultlessly, but dont stall.
i would like to have it correct instead of jury rigging it.
To summerise.
Motor will not idle in water, but will using earmuffs.
Motor performs well at speed, pulls well and smooth.
Compression seems good.
Advance works and hold steady
Sparks good (warning dont touch spark plugs, it hurts)
Plugs are a little oily after idling for a while, but the colour is good so I assume it runs ok at speed.
Any advice would be appreciated.
NOTE
I have managed to up the idle speed by adjusting the cam follower on the carby.
Idles at 750-800 rpm in the water (at 1000 rpm with earmuffs)
Moving the carby cam does not affect the advance, just the carby.
Advance is correct at 3500.
With my adjustment the motor runs fine.
thanks for any help.
with
To summerise.
NOTE
with
