Evinrude 4 hp outboard water pump
Roger Geary
I have been given an Evinrude 4 hp outboard and have managed to get it going, but there is no cooling water flowing out. I need to inspect and possibly change the water pump/ impeller, but cannot figure out how to get at it. Can anyone help?
MGuckin
Re: Evinrude 4 hp outboard water pump
The year of the motor makes a difference. If you are not sure what year it is try here to determine it. You will need the model number. Model & Year Guide <br />Post back with the info.<br />Mike<br /> :)
Roger Geary
The model No. is E4BRC1C and the serial No. is B091164.
Roger Geary
Thanks Captain. The Model No. is E4BRCIC and the Serial NO. is B091164.
MGuckin
As the link I gave you told you, it is a 1981.<br />You have to remove the gearcase to get at the impellor. <br />Not hard on this model but I do recommend a manual. Clymer manual #B732 is easy to follow. About $30.00 US or possibly a library<br />We can talk you thru but it would be better if you had a reference in front of you.<br />Mike
