evinrude 30hp 1989 wont start (e30elced)
Zuruck
Spent $1300 over two visits with a local um.. mechanic for a carb rebuild, motor mounts, and a key switch i probably didn't even need on my 1989 30HP Evinrude. Boat stalled out on the water within minutes after all and hasn't started up since, fuel is being delivered to carb, have spark, compression checks out so highly suspect a carb issue. What should I look at/do next. I'm broke now, I'm going to try to wing this on my own now.
Zuruck
also, spark plugs are dry after multiple attempts at starting. put in brand new plugs.
Honorary Supreme Mariner
Time to find a new " mechanic " as that appears to be more than what one of those sells for in my area with warranty.-----Perhaps check the flywheel key.-----And are you pushing in the ignition key while cranking it over ?
Zuruck
I tried to put fuel into carb directly, did not fire up - at most it seemed to "want" to try.
yes, i am pushing in the key, as I know it squirts fuel - don't even ask how long it took before I found that out haha =P
oldboat1
Oops. Starting procedure might be an issue. Remote should have a fast idle for warm-up.
Zuruck
remote does have a lever to increase idle, i always have it at max to start it. I've had this boat for 6 years, never had such a hard time getting it to crank up.
Also, i noticed fuel is dripping out the lower unit, especially when tilting the motor up. never seen it do that before. Also, out on the water there was a gas cloud.
oldboat1
Likely from repeated attempts to start. Check the flywheel key, as mentioned above.
