Evinrude 30 hp big twin
jfra8843
I recently got a boat with a big twin engine. The engine does start up and run but I believe it Just needs the carb fine tuned I am a very experienced diesel and Car technician but never worked on any boat engines. I have a bag of parts that came with the boat that contains the high idle and low idle knobs and some misc screws but when I put the cover on it the knobs don't seem to hook up to the needles there must be a part missing and I'm not sure which needle goes in which spot on top and button there is a pointed needle and a blunt end needle and they will both screw into both spots if there Are some of you guys who know a lot about these older engines and could point me in the right direction to get the missing parts and how to adjust this carb I would appreciate it. Thanks.
lindy46
If it's a 30hp Bigtwin, it is a 1956. The cowl halves should close around the needles, so the adjustment knobs emerge through the cowl when closed. The pointy needle is the top (slow speed). There is a screw in the ends of the needles. Loosen it and the knob will slip on. Tighten it to secure the knob. The top needle should be opened 1.5 turns to start with, and the bottom needle should start at 3/4 turn. Then adjust on the water. Run the engine at WOT and adjust the lower needle to optimum rpm/speed. Then idle down and adjust the top needle to optimum trolling speed.
F_R
Honorary Supreme Mariner
Pointy needle is upper one, for idle mixture. Open 1-1/2 turns from lightly seated
Blunt needle is lower one, for high speed mixture. Open 3/4 turn.
Those settings are preliminary only. Readjust on a boat, on the lake.
Knobs are held on by tapered screws that expand the end of the needles
You might as well look at the ignition system before going any further. ALL 1956 Evinrudes have bad (cracked) coils unless somebody has already replaced them.
jfra8843
Ok I just ordered a flywheel and starter and bracket for this and a manual it does run now. Will I see the coils when I remove pull starter to install flywheel? And is that all I have to do is remove pull starter and install flywheel or is there something else I will need I see that the flywheel does have magnets in it for the coils.
jimmbo
The entire ignition system resides under the flywheel,
jfra8843
Ok thanks for all the help and one more question does anyone know off hand what is good compression on one of these engines.
HighTrim
85 to 115 or so. Equal between cylinders is key. Most I buy are around 100.
