Evinrude 2hp
dtpratt
I have an Evinrude 2hp (mod# E2RCRS) and forgot the gas/oil mixture. Does anyone know what it is?<br />Thanks,<br />Duane
projas
Re: Evinrude 2hp
Hi, were you able to determine the gas/oil mixture? I recently acquired the same model outboard and don't have that info. Also, I am having a heating problem. <br /><br />The motor runs well when under moderate power but will overheat and quit when pushed to wide open throttle for more then a minute or two. I have changed the impeller, put in a new piston and rings and a new head gasket, all last season. Of course I have tried to clean out all passsages tooAny ideas/suggestions?<br /><br />thanks
dtpratt
Re: Evinrude 2hp
I was told by many people that the mixture is 50:1. Can't help with the overheating, though.
fone_man
Re: Evinrude 2hp
Evinrude 2hp (mod# E2RCRS)<br /><br />E = Evinrude<br /><br />2 = 2 HP<br /><br />R = Rope Start<br /><br />CR = 1984<br /><br />S = Model Run or Suffix<br /><br /><br />Oil Mixture:<br /><br />All, not using VRO system 1964-84<br /><br />50:1 NMMA/BIA Designations TC-W3®<br /><br />Hope this helps...<br /><br /><br /> :cool:
