Evinrude 28hp vs 33hp
BOATERPOPZ
Greetings group, could someone post the difference in bulk weight of these 2 OB's or are they essentially the same? At this point I am without reference manuals. Thanks in advance, JD
BOATERPOPZ
Sorry, the 28HP is a 1964 model 28402M the 33HP is the same vintage mid to late 60's and the model number should be somewhere between
33002 & 33953.
DWM76
You sure it's not 33552? That would be a 65 Evinrude 33HP Ski-Twin
The 28 ad 33 are the same motor as far as the weight is concerned !!
F_R
33752 is a 1967 33hp. Still all the same basic motors and same weight.
jimmbo
Careful, someone will think they can twist a screw, change the jet and they will can turn a 28 into a 33. Never mind the displacement and other things are different
Grub54891
Having a 28 and have worked on 33's, I can tell ya, the 28 Is a much smoother running motor. Idles like a dream, where the 33 is a bit rougher. I'm sure the 33 Has more power, but I won't give up my 28.
82rude
I had a 1970 33 hp tiller Evinrude.Loaded up a 14 foot woody with more than I should of and even had a spare 15hp just in case! It handled the massive weight with nary a grunt.I was impressed .
