Hello all, new to the forum and it's been a few years since I last worked on outboard motors.
I recently purchased a 1985 Evinrude 25HP with electric start (I don't have a battery yet so using the pull start). It is a tiller handle model which I purchased 'as is' and have not seen it run. It was fairly cheap and came with a parts motor.
The problem I am having is that when I pull it over to try starting it, all it will do is 'pop' or backfire out the exhaust, and nothing else. I am thinking this is a good indicator that it is firing at the wrong time. I think the leads going to the coils are wired up correctly as the orange with blue stripe is going to the top coil, and the plain orange is going to the lower coil.
Do you guys think this sounds like a flywheel key issue, or something else? Are there other things I should be checking for? It does have a good strong spark on both cylinders.
